Add volume normalization option
It would be good a volume normalization option , because sometime the streams are much different volume.
I concur! Some local college stations I listen to have their stream set to SUCH a low volume, I have to double the volume. Not sure why they do that…
I was just about to add a request for a per-station gain setting. Similar idea. It’s weird how some stations (college/local in my case) stream at a lower volume level - you’d think it’d be standardized.
One up from me as well. I love the app, but it’s especially difficult to set the right volume to hear everything when using Eter with CarPlay. Some stations are especially loud and it’s impossible to hear navigation directions though the music. It would be best to have some kind of additional volume/gain setting to regulate this disproportion inside Eter app itself.
