Adding files to Trickster’s list
With a System Service “Add to Trickster”.
Either select files in Finder or similar apps or select text that contain paths to files and use “Add to Trickster” service.
With custom URL scheme:
Use trickster-add-recent://fullPath to add the file at fullPath to Trickster.
For example, use in the Terminal as:
open trickster-add-recent:///Users/jacob/Dropbox/Public
For another example, click here to add Preview application to Trickster on your Mac.
Since version 3.8, additional parameters can be added, such as:
source- text for sourcecallbackURL- URL to be opened when Trickster is asked to open a filedisplayPath- text to display in the path section of the item in Trickster. This doesn’t replace the actual real file path. This is only for display purposesbundleID- bundle ID of the application with which to associate the file (for example in the special “current app” filter in the bottom of Trickster’s window).
With AppleScript
Like this:
tell application "Trickster" to add recent "/Users/jacob/Documents/Sample of Xcode.txt"
or even with multiple files, like this:
set fs to {"/Users/jacob/Documents/File 1.txt", "/Users/jacob/Pictures/Picture 1.jpg"}
tell application "Trickster" to add recent fs
The items can also be file objects and not only string paths.
Since version 3.8, additional options are available, like for custom URL command. These are only going to work when adding one file using AppleScript.
Here’s a command that’s used for DEVONthink integration with Trickster:
add recent thePath source appname displayPath recordPath callbackURL itemLink bundleID "com.devon-technologies.think3"
The additional optional AppleScript parameters are source, displayPath, callbackURL and bundleID
Getting recent items from Trickster using AppleScript
It’s possible to get either the recent items as they’re shown in Trickster or the selected items. It’s possible to get individual items or the whole list (which might be slow).
There’s a command refresh entries that forces Trickster to sort its recent entries without opening Trickster’s window. You’ll probably want to use it before getting recent entries.
The list of all recent files (no filters applied) is available in entries elements of application object. A specific item (in this example, the first one) can be retrieved directly with the following AppleScript command: get path of entry 1
The selected items are available as selected entries property of the application object. The path to the first selected file can be retrieved with the following script:
set se to selected entries
set t to item 1 of se
set p to path of t
end tell
The entry object contains the following properties of the file:
url(file, r/o) : The file object itself. Use it with Finder or in other waysfile name(text, r/o) : File name (without the folder)flagged(boolean, r/o) : Is the item flaggedpath(text, r/o) : Full path to the file as textfolder(text, r/o) : Folder of the file as textfavorite(boolean, r/o) : Is the item marked as favorite? If yes, it appears in the Favorites sidebarmodification date(date, r/o) : Modification date of the entry. Actually, it’s most usually the time that Trickster detected this change.uti(text, r/o) : UTI of the entry
All of this information is available in the AppleScript dictionary which can be opened with AppleScript Editor.
As a user of LaunchBar, I wanted to create a way to send files quickly from Trickster to LaunchBar. I also use the fabulous Keyboard Maestro, which lets me assign hotkeys to call these scripts. As an alternative to Keyboard Maestro, you could use FastScripts from Red Sweater, if all you need is call AppleScripts.
The scripts were written with the help of Brett Terpstra and Eugene Gordin.
Script to select the most recent file in LaunchBar:
refresh entries
set f to get path of entry 1
tell application "Launchbar" to open f
end tell
Script to get selected items in Trickster and put into LauchBar for further processing there:
set sel to selected entries
set paths to {}
repeat with i in sel
set p to path of i
set p to POSIX path of p
copy p to end of paths
end repeat
tell application "LaunchBar"
remain active
open paths
end tell
I assigned both scripts to ⌃⌥Z in Keyboard Maestro. You’re welcome to download them.
I also created a custom search in LaunchBar that uses the special URL scheme to add a file from LaunchBar to Trickster. I called it “Add to Trickster”, and can invoke with at. I suppose similar actions can be performed with Alfred or other launchers.
Another usage pattern that Brett suggested is saving these scripts as files in the scripts folder for LaunchBar, thus making them available right from within LaunchBar.
You can also create scripts to copy the most recent files to the clipboard, for example.
Maybe you can think of new ways to use Trickster’s automation. If you think something is missing and you want more automation functionality, let us know by writing in these forums or through support.
Emptying the list of files
Use URL trickster-empty-list: to remove all files from the list, except flagged or favorite ones. This is the same as using the “Empty list” menu item in the Trickster app.
