Bigger or resizable window for transaction
When you import some CSV file from bank account, you got some very long description field
As a result you can’t see anymore amount to the right part of the windows.
I should be possible to resize the windows to make a clear view of amount.
Yes, this requires some kind of a solution. The amount should be visible in any case, even without resizing, so this is a bug we need to fix.
Hi Jacob. Thank you for reply.
Missing amount is when “description” is very long.
As said in other topic, a great feature would be to have the list in a panel on right for example and be able to drag and drop a transaction from one group to other
And even better, from INCOME to EXPENSE (in case of wrong import)
