Cashculator 2.3.0 is now out with the new features: A transactions sidebar, vastly improving your ability to find transactions and quickly operate on them, and a news (or notifications) pop-up in the app’s bottom-right. This will improve our communication with you and, in future versions, we intend to use it to bring notifications related to events in Cashculator itself. Detailed release notes:
New features:
- Transactions sidebar (search transactions or follows selected cell, column or category)
- In-app notifications. In this first iteration are going to be used to notify of new blog posts or other news. Check the bell on the bottom-right of the window.
Bug fixes and improvements:
- Select previously selected category when canceling creation of a new one
- Add new categories below selected ones, when appropriate
- Fix reseting selection in reconcile view after transactions are edited and in some other cases. Selection will still reset for undo operations.
- Remember repeat step and time unit between edits of transactions
- Fixes to CSV Import, including for numbers with currency symbols
