New Features:
- Transactions Sidebar Enhancements:
- Totals display at the sidebar’s bottom.
- Support for multiple-transaction operations including copy, move, delete, and drag-sort. Totals update for selected transactions only.
- Display of repeat counts and new icons for recurring transactions.
- Improved Navigation:
- Switch keyboard focus between sidebar and spreadsheet table with T.
- Set start/end dates for the sidebar from the selected column in the spreadsheet:
- Using new buttons near the dates.
- Using keyboard: Press S to take the column’s start date and E to take the column’s end date.
- Access sidebar search field directly with Command-F.
- If called from sidebar, will just focus on the field
- If called from the spreadsheet, will reset to All Transactions and clear it before focusing
- Delete selected transactions in sidebar with the Delete key.
- Sidebar User Interface Updates:
- Move and Delete transaction buttons relocated to the Totals area.
- Enhanced animations and sorting.
- Improved sorting by transaction note.
- Animated some changes.
- Improved keyboard navigation.
Bug Fixes and Improvements:
- CSV Import Enhancements:
- Fixes for recognizing numbers with thousands separators and parsing dates in two-year format.
- Display adjustments for dates and monetary values.
- Icons Update:
- New icons for recurrent and non-recurrent transactions to improve clarity.
