Cashculator 2.9 with Category Breakdown chart and more
Version 2.9
This release introduces a new powerful Category Breakdown Report and refreshes the chart experience with improved design and functionality, along with enhanced transaction management workflows and bug fixes.
  • NEW: Category Breakdown report – A comprehensive new report that shows your spending patterns
    • Interactive charts with drill-down capabilities to explore spending by category or group of categories over time
    • Click on categories to focus on specific spending areas
    • Detailed breakdown tables that let you see exactly where your money goes
    • Works for income and expenses
  • NEW:Record Actual” transaction feature for manually creating actual transactions from your planned ones
    • Perfect when the actual transaction date or amount differs from your plan
    • Works with both automatic and manual planned transactions
    • Access in the Quick Viewer (transaction list of a table cell) with the new button in the bottom-right corner
  • IMPROVE: Charts now feature a fresh new design that automatically adjusts to your chosen color scheme and show precise values for a hovered chart point
  • FIX: Crash that could occur when deleting transactions from Quick Viewer
  • FIX: Table layout problems that could occur changing view scales or entering transaction that change column widths
  • FIX: Too narrow columns when showing mixed positive and negative values in Both view
Version 2.9.1
This update enhances chart visualizations and improves the overall user experience with better dark mode support and more accurate data display. We’ve focused on making charts more informative and visually appealing while fixing several issues that could show incorrect data.
  • IMPROVE: Category Breakdown charts now use better 10 distinct colors instead, making it much easier to distinguish between different categories in your financial reports
  • IMPROVE: Category Breakdown charts’s tooltip now highlights the name and amount of hovered bar segment, making it easier to see what group or category that is
  • IMPROVE: Category Breakdown charts can now properly display negative values below the zero line with a clear baseline and net indicator diamond
  • IMPROVE: Reconcile section now shows helpful error messages when you try to edit calculated balances, clearly explaining that only past manual starting balances can be modified
  • FIX: Chart date labels now display correctly for users in time zones east of UTC (previously showed incorrect dates)
  • FIX: Dark mode text is now clearly visible when editing reconcile balances (was showing dark text on dark background)
  • FIX: Category Breakdown graph now remembers whether you selected Income or Expenses when switching between reports or changing time scales
  • FIX: Chart totals and tables now update correctly when changing time horizons or scales in Category Breakdown report
Version 2.9.2
This maintenance release focuses on stability and user interface improvements.
Thank you, all the users who reported bugs.
Fixed:
  • Delete button not clicking in Plan Quick Viewer
  • Editing a recurring plan transaction in full-screen mode closed the document
  • CSV export can’t save to a custom file name
  • Category names not displaying localized in chart tooltip views
  • Crash that occurred when quitting Cashculator with the horizon popover open
  • Horizon panel’s appearance on macOS 26
