Hi,
Why I can’t click and play a station from My Stations section?
Thanks
Hi,
could you provide us with some more information, like the device, operating system?
Kind regards
Krystian
Sure, ı am running Eter Radio 2.2 (106) on MacBook Air M3 running Sequoia 15.0.1
I often have the same issue. To solve it, I run it from menubar.
I have never observed it on my Mac, and I so far I couldn’t replicate it with the current version on macOS Sequoia 15.0.1. Do you click directly on the title of the station in the list or do you just click on the row of the list next to the title of the station?
Could you record a short video/screencast with this, that would possibly help me with solving this issue?
I think I found the solution. In order to change the station under My Stations, you have to be listening to a station. If not playing, you can’t click and change or start streaming a station.
OK, anyway I will look into this more carefully! And thanks for using Eter!
