Disable artwork lookup per station?
Using Eter to listen to TalkRADIO in the UK. The metadata in the stream has a dash ‘-’ instead of a programme/track name. This causes Eter to retrieve the artwork for (I presume) a track called ‘-’ from Separation Anxiety by an artist called Nell.
Is it possible to disable artwork lookup for certain stations or ignore obviously incorrect metadata such as a dash?
Thanks in advance.
Hi,
I see the problem. “-” is treated as a song title.
I will fix that.
Best
Krystian
Hi Krystian, thanks for the v3 update, really nice new features.
Just wanted to point out that I’m still seeing this problem in the new version, guess the fix may still be on your backlog, but wanted to flag it in case something’s slipped through the net :slightly_smiling_face:
Thanks in advance.
