Hi mates, i am trying add this radio so i cant add it. Could you help me ? Thanks a lot.
To add a station, add it through radio-browser.info
It will be added not only to Eter but also to many other apps that use the same database.
Tks. They close adding to new radio station.
Oh, wow. We didn’t know that. We do host our own copy of radio-browser.info so we could add them only for Eter but there’s no public way to do that now. We’ll think of something. Maybe we can add this feature in the app.
Have you tried adding it manually just in Eter? I initially assumed you meant adding to the database, but I’m now unsure whether your post was about manually adding this station for yourself or directly into the database for everyone.
I meant adding it to eter. I tried but couldn’t add it with that radio URL I put in my post.
I see. Sorry about misunderstanding the first time you asked.
To add a station manually in Eter you need to find the exact URL of the station audio stream, not the web page. This may be tricky to find and may also change. Depends on the technology used by the station.
Specifically, for PureGlowRadio.com, the actual stream URL currently is https://pureglowradio.ice.infomaniak.ch/pureglowradio.mp3 (I had to find it by playing in the web browser and then see which URL the web player was using).
So you can try adding it manually in Eter (works for me on Eter for Mac).
No problem
My English isn’t that good either. Before posting, I tried to do it myself, but I couldn’t find the stream URL and didn’t have much experience with how to get it. The URL you gave me works perfectly on eter ios/mac. Thank you for your support and time.
