I’m starting to play a bit more and was going to enter a bill that only occurs once every year. But I want to be able to save 1/12th of that bill each month. In CC1 I would type the value / the number of months and it would fill for the period specified. How do you envision users do this with CC2?
I can see that the 100*6 and 20@2 case are easily handled with CC2, and I can even see how adding multiple entries into a single cell acheives the +. But I can’t see an easy way within CC2 to do the 12000/12 case without using a calculator outside of CC2.
Yes, there’s no way to do that now. The / shortcut in CC1 would also create the “transaction” itself over the specified number of months, which is probably not what you want here.
I think that at the moment it’s not so important as dividing is easy to do in Spotlight or any other calculator (if the problem is to get the number right).
I did think about having some of the old shortcuts like @ work by turning on recurring options and switching the focus there, as a quick shortcut. Of course, it can also be any other shortcut, this will just be consistent with CC1 (but strange otherwise).
