This release introduces oval frame designs — a major new feature that brings rounded, elliptical framing to ImageFramer. Oval support extends across color mats, molding frames, corner frames, shadows, and bevels, with realistic 3D-lit bevel edges. The release also includes important rendering fixes and improved reliability for frame library downloads.
- NEW: Oval frame designs — create beautiful elliptical frames with color mats, molding frames, corner frames, and realistic 3D-lit bevel edges. Enable it in Design Settings panel.
- IMPROVE: Lightroom plugin now works with the Mac App Store version of ImageFramer
- IMPROVE: More reliable frame library downloads with better error recovery
- IMPROVE: Updated app icon with a fresh new look, designed for macOS 26
- IMPROVE: Improved look and feel on newer macOS versions
- FIX: Shadow blur now renders correctly after adjusting layers
- FIX: Fixed the app becoming unresponsive in some cases
- FIX: Undo/Redo fixes in Library Editor
