Spelling and grammar check in expense description field
While using cashculator, and entering many expenses back to back, making small typos add considerable overhead sometimes. I wonder whether is it possible to enable spelling and grammar checks in Description field in expense entry dialog.
Since Apple’s own implementation is good for correcting simple typos and detecting language pretty quickly, I think it might add some more polish to the UI.
Cheers,
H.
Thanks for the suggestion. We haven’t noticed it wasn’t enabled. We’ll add this to the next build, hopefully.
Hi @Jacob,
Thanks for the quick reply. I’ll be waiting. :slight_smile:
Cheers!
It’s been done in code and will appear in the next update. Thank you for waiting.
Hi @Jacob,
Thanks for the heads up. Eagerly waiting for the update to see what improvements in the store.
Cheers,
H.
